I also have a Tiger River Bengal with IQ2020 control board- with a heater control issue. After applying power, the power indicator turns on, then the circulator pump kicks in. After about a minute the power & ready indicators start flashing.
Everthing had been running fine for a few weeks after I got it filled again ( I winterize it every fall & bring it up in May). The circulator pump went out, so I replaced it. It has good flow- there are plenty of bubbles from the bottom drain with the circulator running ( &ozonator on). Shortly after that the heater stopped & behaving as described above ( flashing power & ready indicators). Heater is fine, measures 10 ohms, but the HTR ON LED on the board does not turn on. The LIM THERM (thermistor) LED indicator above HTR ON is solid green.
Both thermistors measure 10k ohms with the temperature at 76 degrees, so I believe they are also good. The pressure switch reads 0 ohms. From what I've read, it should read 0 ohms. Is there anything else I can check?
