buriboi
  • Content Count
    10
2 Neutral
About buriboi
    Junior Member
  1. Yeah, figured as much. Maybe if I yell and scream at the local dealer enough about all the problems this piece of junk has experienced, they'll give me a decent deal oh well, thanks for all the help - it's very appreciated!!
  2. @CanadianSpaTech Now that I'm done with pornhub, I can bring my attention back to this pesky spa pack. I removed the pack and snapped some pictures of the rear of the circuit board. Looks pretty untouched to my very untrained eye. Thoughts?
  3. @CanadianSpaTech So if the topside panel is unplugged, after powering on, it took 20 seconds to hear a single "click". That same click then repeated every 10 seconds indefinitely. So you think whole new spa pack required? No reason to take it out and check the circuit board, hoping for a better outcome?
  4. @CanadianSpaTech Quick Update, I finally found the time today to get this done. Buuuut, just before I was about to follow your instructions to take the board out full, I noticed the wire for the topside control panel was loose. So, I plugged it in fully, and the panel is getting power, as opposed to none. This change might not make any difference whatsoever in the troubleshooting, but I wanted to explain exactly what it's doing now before doing too much else. Control panel is now back to showing the sequence: 8888, 294, r6, LL39. It'll click, then, 10 se
  5. Well, since I'm working from home with this COVID thing, I guess I can find some time to try it myself My skill level is pretty damn low, but I'm decent with following good instructions, I suppose.
  6. Well, since I'm working from home with this COVID thing, I guess I can find some time to try it myself My skill level is pretty damn low, but I'm decent with following good instructions, I suppose.
  7. Hi all, Just wondering if any of the wise gurus in this forum have any thoughts before I have to shell out big cash to repair my hot tub. 2015 Hydropool Serenity 5000 Gold. Issue: Tub was working normally. We turned the power off to drain/clean it, then refilled it with fresh water (no different than what we do every 6 months). When it was full, we flipped the breaker back on, and rather than the usual pumps and jets starting up after a few seconds, we just hear a "click" from the spa pack, following by a 10 second delay, then another "click". It does this over an
