Hi bought a house very cheap because solar that heated pool on roof leaked causing a hole in roof. Now solar was removed and pool plumbing (Solar)capped off. So when I turn on my pump it works fine however when I go to hook up pool sweep in skimmer it does not move it’s almost as if the pump stops working also. I’ve checked for leaks on hose on lid at unions I’ve used a drain bladder at pump and skimmer. However there is a Jandy valve that is labeled solar on one side and pool the other when I turn valve to pool I hear a rush of water in pipes at pump I’m not used to hearing however it actuall
