We live in England & inherited a 13 year old Clearwater Beechcraft Spa when we moved in 8 years ago. I am a private individual, but due to Coronavirus, I can’t get a professional Hot Tub engineer to visit. So I’m hoping I can get some help. The circulation pump is an EMG ( Italian) pump and is now leaking between the wet and motor side and it is almost certainly the seal. I have removed the pump and it is very calcified, rusted and generally in poor condition. I am unable to remove the shaft to see if I could replace the seal and have given up. I suspect the pump needs replacing anyway. I do not think this is the original pump as all the 4 jet pumps are Waterway Pumps. ( 11.4A HS 3.2A LS)
I can find nothing on the internet about the EMG (Italian) circulation pump I have, but the data plate on the pump tells me the following
Model 202SA0701
Type 63/4 ( I don;t know what this is?)
RPM 1450-1740
A Max 0.9
KW1 Max 0.19
PH 1 ( I don’t know what this is?)
Fittings are 2 Inch.
The Spa volume is 2044 litres / 540 Gallons
On researching, I believe I currently have a two speed pump ( the RPM range apparently tells me that?). However, I cannot find a circulation pump with 2 inch fittings that has Max amps of less than 1. In fact most seem to be between 5 and 9 amps. I am worried that I might damage the main PCB in the Hot Tub if I use a bigger current or RPM? The existing pump is currently wired for two speeds, but what would happen if I wired in a single speed pump? Would that damage anything?
I can do the plumbing ok – but any help with the question of current and what type I should get would be a big help. The LX models seem a lot cheaper than Waterway & Aquaflow etc, but I guess there is a reason for that. Thank you.
