I need some advice. We have a pool with an attached spa. Whenever we switch the system into spa mode everything works correctly the water is recirculating inside the spa as it should. However, 8 out of 10 times the jets don't create enough pressure to become "jets" water is flowing out but not at high pressure. Oddly enough, I have discovered if I lower the amount of water in the spa the jets pressurize every time. For the life of me I can't figure out the science behind this or where the problem lies. Pump is only a few months old and it was doing this before the new pump as well. Filter is new, valves are new same result. Does anyone have any ideas on what might be causing this issue? Thanks!
