clh42
  • Days Won
    1
clh42 last won the day on September 23 2020
clh42 had the most liked content!
clh42's Achievements
1
  1. I've had a slow leak in this tub for a few months and finally got around to tracking it down. The basic question, can this even be fixed? It's not a "part" that's leaking that I can just replace, I don't think. It doesn't look like much of a leak but it's about half the tub every 3 weeks. See photos for reference. The 3rd photo is the main one showing the actual leak and where it's leaking from, circled in red, and the darker black coloring pointed to by the red arrow is the small stream of water. The first two photos are for showing a frame of reference for exactly where this is in the compartment. From what I can tell, it's leaking from the hole that that hose goes though. It MAY be the hose itself that's leaking but I can't tell. I believe this is the small hose that comes off of the front of the rear jet pump, just as that front small hose is coming off of the front of the front jet pump and feeds in through that small front hole on the left. Even if I could somehow get back in there and maybe caulk around the hose, does that mean there's a larger issue inside there? Or even if it is the hose itself leaking, can that hose be replaced? Where does it go once it gets down inside the frame, and how would the other end be accessed to replace it? Thanks much!
  2. I did get this figured out. The spa light had died, shorted out apparently. There are two connections from the spa light to the main board. After unplugging both connections, the spa powered up again. I may replace the light someday but for now, just running without it.
  3. HotSpring 2006 Vanguard. Tub just suddenly up and died last night. It has no power at all. Control panel won't light up or respond, no LEDs on the main board are lit, no pumps running. Breakers did NOT trip. I've already tested and verified that I have 240 V coming in to the relay board for both the 20 amp and 30 amp circuits. And the white, black, and red wires that go from the heater relay board to the main board are carrying power to the main board. Is there anything other than a bad relay board or bad main board that could cause a complete loss of power? Or does it just come down to having either a bad relay board or a bad main board? And if it does have to be one of the boards, is there any way to determine which one is bad? Thank you!
