Hello all, I recently bought a new home that came with a hot tub that I just got going. I had a new pump installed. I have a few questions and observations that I would like to run by the community.
Make - Thermospa
Model - Chesapeake, I believe 5-person, it is most likely between 8-12 years old.
The controls are pretty straight forward I think. Three buttons - Pump, Blower and Light. Up/Down for setting the temperature. On push of the pump is low, second high and third off. Correct? Question, if I use the hot tub and have the pump on high and leave it, will it eventually power itself to "low". I think I left it on high last night. The blower automatically turn off at 30 minis correct?
The unit has a "1900D" controller and the LED's to display the temperature are failing I believe. 100 looks like 170 for example as well as other anomolies. This makes it hard to set the temperature an not know whether you are going up or down. The thermospa brand controller is $225 and there is a Balboa replacement that looks suitable for $115:
https://www.spaguts.com/products/balboa-topside-kit-digital-duplex-vl404-51223-6941.aspx?keyword=&gclid=Cj0KCQiAg_HhBRDNARIsAGHLV53MEV85HWr6odEPd_XC70MIw97u2NFXuCvImkVvYenbrtc00cLhqXgaAu7qEALw_wcB
Any experiences here with Balboa? Should this work ok? These look like they are hard wired into the controller and then plugs into a panel with an ethernet type jack. The thought crossed my mind to cut the cord of the old and splice in the new to save myself trouble of removing the side panel. The hot tub is sunk into a deck. Bad idea? I am fairly adept at splicing, soldering and heat tube shrinking.
The cover it came with was the original and really old, ripped and frozen water-logged (very heavy). I was still using it but losing 3" of water every 24 hours. I have no leaks to speak of. It is 20 degrees here in New England I a believe it was evaporating quickly because of the poor cover and insulation. I got a new cover a few days ago and I "think" the water level is holding. Can a poor, old, ripped cover cause evaporation?
I am keeping it set at 100 and even though it is tough to read, I have a thermometer to support it.
I think that's it for now with questions. I am going to read the other thread. Any tips, answers, words of advice greatly appreciated.
Thanks,
Joe
