Hi all,
We recently got a 2004 Caldera Spas Utopia Geneva from some friends, built a deck and had it wired up but I'm having a problem. After turning both the 30 and 20 amp breaker on, the spa starts up. The 'LIM OK' light comes on and the 'HTR OK' as well. The circulation pump starts working and after 5 minutes it goes into the auto clean routine. The air blower starts and runs for a minute but when Jet 2 turns on low it trips the 30 amp breaker after a second or so. If I manually start Jet 1 or 2 it trips near immediately. I released the union on top of both pumps and only found one to have a small amount of air in it. I know several have stated disconnect each component and then try but if the air blower and heater can start without tripping either the 30 or 20 could it be one of those? I'm just puzzled as to why both pumps would be bad. As a test the electrician bypassed the 30amp GFCI breaker and wired the 10AWG lines directly into the main 50amp feed coming into the subpanel. The pumps will run fine that way but it's not a permanent solution. Does this point to a GFCI issue? The load neutral is connected to the 30amp breaker. The only wiring deviation is a convenience GFCI outlet wired off the 20amp breaker. The electrican says he tried running it with that disconnected with no luck but I wasn't standing over his shoulder at that point.
We know the tub was sitting for some time so the goal was to run it long enough to heat the water and then use a jet purge and drain afterward but if I can't get the jets to run without tripping. So that's not an option unless I go back to that 50amp GFCI bypass just for cleaning if that's recommended.
I know you guys get a lot of random drop-in 'Help' questions but any advice or direction is helpful. At this point we have several thousand plus dollars into a non-working hot tub.
