Hi,
My aqualink was intermittently either not turning my pool pump on or not turning it off during preprogrammed schedules. I looked on this site and others, I found people asking the same question and the consensus was that it's a faulty relay.
I purchased the appropriate relay replacement. Turned off my power, labeled each preexisting wire placement, removed the old relay and installed the new one. It was very easy to do and I thought of what a genius I was and how much money I just saved......
Unfortunately when I powered the system back up, now nothing works. The interior control panel showed Firmware rec B09. This code is not in Jandy's manual. Reading online I think it just may be the firmware version of the unit. The manual says that if I get a message with a dotted screen I should disconnect power for 2 mins and try again. I did so several times, same issue. Now not even the lights came on over the buttons in the box outside where I replaced the relay, they did previously.
I removed the new relay, reinstalled the old one. Again being certain to keep the wires in correct order. Same problem, nothing works. I'm guessing I did something to destroy the main circuit board but I'm not sure what.
So if anyone has any suggestions before I purchase the 2.0 upgrade board for $629. I'd appreciate the help. Thank you.
