Just an update on my problem which I have solved. I mentioned that I tested the temp sensor with an ohm meter and it reported accurately. Well it was reporting accurately at the time I tested it, BUT it was an intermittent Watchdog problem so an accurate temp reading makes sense SOME of the time. Anyway, the spa kept going into Watchdog every day or two and I kept resetting the power. Fortunately one day I reset the power and the panel came back on and showed 110 degrees and OH. I was so happy to finally catch the temp sensor when it was reporting inaccurately - the water was only 102 degrees. So I installed a new temp sensor and everything is fine once again. Moral of the story - don't trust that a metering check at one point in time is telling you the whole truth.
