Tubber49
38 -
Days Won
2
Tubber49 last won the day on September 7 2022
Tubber49 had the most liked content!
Tubber49's Achievements
3
Thank you! I'm still pinching myself! Really though, for all those folks who think it may be a major production, go for it! Most of the newer packs are easier than this one, no plumbing required.
I'm not sure if I'm posting this because I'm so excited and am about to head for a soak OR to encourage other tub owners that THEY CAN DO IT! So after a few weeks of searching and debating about spending the money on my tub, I walked into a yard sale on a Saturday morning. There was a spa pack in a box in the garage. How much I ask? $20! What do I have to lose? I can't get a pizza for $20 these days. So here I am. Heater was longer than my other pack. Needed a pump cord. $20 for the cord, $25 for the PVC and BELIEVE IT OR NOT my topside control fit! So if your tub doesn't leak, you're happy with the jet situation, etc "GO FOR IT" (It wasn't working anyway!) Happy Tubbing, everyone!
CanadianSpaTech, Mike223, Spa Shop, Thanks for all your help. I got nowhere and couldn't get to much because the rust was too heavy and couldn't get the parts out. So my AP4 is now retired. There is more to this story but it will be on another thread. Thanks again I love this forum!
It's a Spabuilders AP-4. Running on 110 v. I'm off from work Thursday and will check the heater. First chance I've had since life happens lol. But I did take a pic of the control box. Don't know if that will help. I really appreciate the help.
I'm not sure how to test it BUT if I jumper the pressure switch, the same thing happens. Lots of other things going on lately, I hope to get to this later in the week.
Brand new heater. No Ozone. Will see what happens when I have some time this weekend. Sigh....
Well, the pressure switch is in and the heater comes on but blows the GFCI after running for about 10 minutes. Can't help but think my next move is to pull the contactor(s) out and see what that water did to the wires I can't see. Any other thoughts would be appreciated.
So frustrated because I can't come up with an answer. Only happens when I turn the heater on. But I just discovered today that my pressure switch is leaking and my control box is pretty wet. Ordered a new pressure switch. I'm hoping once it dries out and I put in the new switch, the problem will solve itself. What I can't get past is why the pack runs just fine and only blows the breaker when calling for heat. Wondering if the heater contactor getting so wet is the issue. So while I wait for the switch to arrive, looking for thoughts to calm my racing mind! TIA
Heater is tripping the GFCI. OK, seems easy enough one would think BUT not when I turn the heater on. It's a 110 tub so I've been running the pump with no heat just to keep it from freezing up. So I turn on the heater and the heater runs for 6 hours before tripping, 3 hours before tripping, 4 hours, all sorts of random times. The tub is now up to temp and I can go out and and turn it on and rely on it to run until ???. By the way, I can see how long it ran until tripping by checking the timer. Any thoughts??? BTW, it NEVER trips with just the pump on. TIA
After working just fine for forever, it seems, my AP-4 tripped the GFCI. I disconnected the heater, tested and ordered a new heater. Meanwhile I kept the circ pump running so there was no chance of freezing up. Replaced the heater today and it's still tripping the breaker. No sign of wire problems but I did notice that one of the contactors is running very hot, so hot I can't keep my fingers on it. Could that be the problem? The heater was really bad with a rust spot where the pressure switch had leaked a while back, so it didn't surprise me that it was bad. Any thoughts? TIA
heater Heater won’t go above 81 degrees
Tubber49 replied to Tpijn's topic in Portable Hot Tubs & Spas
Bypass it temporarily (GOOGLE OR YOU TUBE) and see if the temp goes up. Is there a light that shows the heater is on? wait and see if the temp goes up. Then you need to determine if the switch needs adjustment or just needs to be replaced. -
Check the pressure switch (if there is one). There might be flow because the pump is pumping but the switch won't allow the heater to come on because the flow isn't enough. The point of the pressure switch is to turn the heater off to prevent the heater from being damaged. The heat of the pump may be enough to keep the temp at 81 degrees. Jumper the pressure switch to see if the heater comes on. If it does then you need to either replace or adjust the switch. Worth a look and a try. -
Even with no heat on my pump running can raise the temp 5 degrees when it's that hot out. I actually had my heater go once and kept the tub from freezing by just running the pump because it stayed somewhat heated.
Look at you go!! Heat would make me happy without the jets or blower (but I'm pretty simple LOL). I still need to check out my controls but my weekend is just Monday this week. I'd wait until the manual arrives (SOON, PLEASE!) before I go digging out more foam. My blower sits right up under the top of the tub to the right of the control panel because of the way the air circulates so that water doesn't get into the blower (don't remember what it's called). You may want to look up and see what's up there....may solve some questions!
