I just installed a Del Spa Eclipse ozonator on my 2010 Sundance 880 Cameo spa. The problem is that the ozonator will not turn on. The indicator light on the ozonator does not light up nor does the icon on the control panel. I am running the spa in Standard Mode, the summer logic is not active and it is plugged into the pre-wired green plug on the spa pack. There is no voltage at the terminal block on the spa pack when the circulation pump is on. I have been through the manual several times and I don't see anything that indicates there are any jumpers that need to be changed and I can't find anything that suggests that the spa needs to be programmed for ozonator operation. I was randomly going through the programming options and at one point the ozonator icon and the light on the ozonator did light up, but that only happened once. I'm starting to think that I have a bad board, but I'm a little reluctant to replace the board on an educated guess. Has anyone else run into a similar situation with a Sundance Cameo? Even though the spa is prewired for an ozonator, the is the first time an ozonator has been installed. If the board is bad, is it possible to wire the ozonator directly to the circulation pump terminal block so that it bypasses the ozonator section of the circuit board?
Tom
