So I drained my hot tub this fall, I thought I had all of the water out, but I didn't blow air through the pipes like I should have. (big mistake I know)
I have a 2002ish Marquis Ultimate hot tube. (An oldie but pretty good one for that age)
Anyway, I went to fill the tub today and as I was filling the tub it was taking quite a bit longer than normal and water was coming from what seemed like under the hot tub. I eventually got the tub filled, but when I went to turn it on, it kept tripping the breaker, not allowing me to even turn the tub on to begin the cycle process when to re-fill it each time.
After doing some investigation I realized I have a major leak. Since I turned off the garden hose, it has dropped about 2 feet and still going.
There are are 5 intake filters (I assume that is what they are), 2 floor jets & 1 drain.
I will also add, I have changed all three motors (or gaskets) over the years and have easy access to the motors and heater and the leak isn't coming from this area of the hot tub.
Suggestions from here?
