I recently bought a K-2106 kit which is supposed to be the bromine kit, but it had the wrong reagent in it - R-0871 instead of R-0872. So I basically had the same problem you had, and I can confirm that the only difference seems to be the amount of bromine per drop when you do the Chlorine test. The conversion is:
Sample ml
Chlorine/drop
Bromine/drop
10
0.5
1.125
25
0.200
0.450
44
0.114
0.256
So you can follow the directions for the Chlorine test, but use the units above instead of what's printed in your test kit.
I am not familiar with the other test kits you list, but I would assume that the bromine one contains R-0872 and the chlorine one contains R-0871. The photo for 1515A suggests that. 1515C looks like the identical kit with 2oz bottles of reagent instead of 0.75oz. The pricing of these kits is so similar that I'd get the smaller supplies of reagents as there's essentially no savings to the bigger bottles. Shelf life concerns would make me worry I couldn't use the 2oz bottles fast enough.
The photo for 1517A also matches my expectation - the difference being it contains the R-0872 reagent.
I think the bottom line is you can do what you need with the test kit you bought, and you have a bunch of extra chemicals you will never need or use.
