I recently bought a home which had a hot tub included with the sale. We finally got it up and running and have noticed it loses heat more than we expected it to. We are in eastern Canada and have had some nights down to -4C already.
For example a night not long ago it was -3C and we had 4 bathers in the tub for approx 1 - 1.5 hours and the tub was down to 100 (from 104 set) when we got out. I left the cover off for another half hour after we got out to add chemical and the tub was then down to 98. One set of jets was running most of the time, 1 bather had the air turned on for most of the time.
The tub model is Legend by Platinum Hot Tubs. The spa pack is a Balboa HS200VS with a 4.0kW heater. I've noticed in researching tubs this is on the low end of heater ratings, with 5.5kW being more common.
So I have a few questions...
1. Is this amount of heat loss normal? I hope not because its only going to get colder here, often down to -15C or -20C.
2. Is a heater upgrade possible on this pack? I've seen some recommendations elsewhere saying its never a good idea to upgrade a heater but what makes me think its possible is that the circuit board (P/N 55098) used in this spa pack is the same as a VS510SZ by Balboa which has a 5.5kW heater. And would it make a difference as far as heat loss is concerned? My spa is wired up to a 60A breaker.
I've also noticed Balboa sells secondary auxillary heaters in various kW ratings, obviously one of these would require additional wiring but is it possible to retrofit these or are they only installed by spa manufacturers?
Any help would be great, thanks.
