I have a need for some lighting and therefore a separate 115v 15amp circuit and the nearest location is the Hotsprings spa sub panel. Now I know the Hotsprings spa requires a dedicated 50amp circuit. Still I was considering - if okay to tie in to the 20 or 30 amp breaker for some low voltage led lights. I realize this is not code but I believe the spa draws near the maximum required amps on both the 20 and 30 amp breaker.
1. Has anyone else done this tie in successfully?
2. Did you tie in to the 20 or 30 amp circuit (i'm considering adding a single 15amp receptacle)
3. I have No other option except and extension cord
Thank you
