Hello,
I have a Sundance Palermo and have noticed a small leak that is getting worse. The leak is located at the plastic attachment on a black box behind my control box. There are two nuts that can be tighten by an Allen wrench, but that has not stopped the leak.
I believe the hose is coming from the circulating pump. I'm curious what this is for? Can I remove the two Allen wrenches and swap out a seal or seal it with an epoxy? Would the spa need to be drained or if the pump is not active would I be able to remove this while full?
Attached are some pictures to help.
Thanks in advance!
-Mike
