Hi,
I have a problem maybe you can help with. I have a 2008 Tiger River Caspian hot tub.
When I power it up, the Power light blinks and I cannot use it. The circulation pump is running as expected, but you cannot turn on the Jet Pumps.
My owner's manual call this error code a "High Limit Reset" and to check for blockage. I was not able to find any blockage in the filter area.
So then I was thinking maybe one of the sensors was bad. There are two of them, the thermistor (which I believe to be the high limit) and the thermostat. I snipped the wires to both and then connected the two wires that were inside each (with the assumption that these things are just basic switches). I tried with both switches on (wires connected) and both switches off (wires apart).
Still no luck. Still same problem.
Where do I look next?
Thanks in advance for help!
