paalwille
paalwille's Achievements
  1. Hi again. I have checked the valve,and compared to the valve next to it,it looks good. When valve is removed,there is no airflow in the "valve hole" no matter what position the Smart Lever is in. Any other tips?
  2. Thank you for that. Will I get to the piston by dismantling the valve from the top..? Would appreciate it if you could explain closer how I get "under the hood" /Paal *EDIT* Found a How-To online. Will try tomorrow.
  3. I have a 2012 Hotspring Sovereign. My double Moto massage jets has stopped going up and down, and I have narrowed the problem down to the air flow in the moto massage compartment. No air comes out of the nozzle in the Moto Massage compartment. I have already gone through the following steps: -Changed the Moto Massage jets ( vertebrae tubes) -Changed the air hose with manifold - Turned all control valves in different directions -Cleaned filters (Tri-X) - Run the jets with filters off for a couple of minutes -Checked the air inlet in the service compartment All other jets works fine and are stable Any suggestions from you?? Paal
