Hello, I follow Nitro's Dichlor then Bleach method. I am having an issue with PH drift and TA numbers however. First, I get CH to around 130-150, I then got TA to 80, Then, following his guide, I turned on all pumps and aeration and tested PH. Once PH drifted to around 8, I added muriatic acid to bring it back down to around 7.5 (I do a little at a time). I let it run another 30 minutes, tested again, added muriatic acid to bring it back down. By the time I got PH to stabilize from drifting (at 7.6), my TA tested low at around 40 which I am reading is unstable. If I add Baking Soda to get TA up again, won't PH drift be an issue once again? I'll be right back where I started I would think.
Thanks
