I have just had a heater failure. It trips the GFI and when disconnected the tub pump runs. There is a build up of which crystalline material around one of the electrical connections and a support bolt. See picture. This white build up is new since I last changed water about a month ago, or at least there was none on floor below heater. While it appears that there was some leakage that formed this deposit under the heater as well, it was not leaking when I opened it. The brown material around the electrical connection has been there for at least a year.
I'm using the Dichlor/Bleach method to sanitize my water and have been extremely happy with the results. I've got a Taylor test kit and routinely check pH and free chlorine. pH is almost always around 7.4 to 7.6, although I've had occasional episodes where pH might have gone high or low for a day or two. I usually test pH about 3 or 4 times per week. I maintain free chlorine around 2 ppm, maybe a bit lower. I add calcium increaser to get my CH up to 150-160 at start. I adjust to get TA to 80-90. Usually I don't have to add anything, that is where it falls out after increasing CH.
My hot tub supplier told me that my warranty claim will likely be denied because this appears to be a chemistry problem. Whatever, I just want to get to the bottom of what happened so I'm not facing this again in a year.
Any thoughts as to what causes this kind of failure appreciated. Also, what should I be looking for when I take this heater out? Should I be concerned that my pump is also at risk?
Thanks.
