I've looked around and have seen this topic before but most threads stop before a solution is given.
I am getting 4 dashes in the display of my caldera. The circ pump is working, water is coming out of the small jet undear the one seat. I tried removing the filter, jumping the pressure switch on the heater, removing the heater and blowing through to see if there is any debris and there isn't. I can blow air through from the inlet side but can't on the pressure which side but I would think that is normal, tried disconnecting power to the heater. These are all things I've read to try while looking for a solution. My manual says the the cause of the dashes is the high temp limit thermostat tripped. I would assume that's that's the sensor that screws in the the tub below the display panel?
Any ideas or suggestions on what to try next?
