Hi,
I have a leak under my Artesian spa and I would like to read you.
I've called an authorized Artesian technician (i'm in Canada/Qc, we do not have a lot of Artesian stuff).
He changed the bottom drain fitting + a part of a pvc hose where the glue looks like weaky.
As requested I left the spa sit for 48 hours (for the silicone to dry) and then I filled it up yesterday.
I restarted it...and after +- 12 hours, I still notice a leak from under the spa.
It is really a slow leak, in 12 hours I can't notice the level of water has dropped inside the spa...but when I look where I removed all the insulation, from the side of the spa, I found some water (picture attached).
https://drive.google.com/drive/folders/1fVdDwxu_WN8RkDbi_s6Xx5O-hsFd4oXp?usp=sharing
In the picture that we saw the under of the spa I putted in orange circle the part that has been replaced...and in rectangle where I found the first accumulation of water (before the reparation)
In the white rectangle it is where I found some water this morning.
I emailed again the technician, but I would like to read all your comments.
Winter is coming soon here and we will begin to get some freeze in the night.
Thanks,
