Hello,
I am hoping someone can help me with this problem, My spa will not heat anymore past 86 degrees unless its hot outside. everytime I run the spa heater it also turns on the pool filter pump and the jacuzzi water spills into the pool. It used to be able to run the spa heater alone and the pool heater alone but now its stuck doing both at the same time. everytime I try to turn off the filter pump while running the spa heater, I get this message: "pump will remain on while spa is on" then if I shut off the spa heater it shuts off the filter pump after a cool down?? I am new to this so I am not sure how to navigate the controls. I have a Jandy Aqualink RS12 system and If anyone can help me figure this out, I would be grateful. Thanks so much and please let me know if you need more information.
Bobby
