Hello,
Can someone tell me how to remove the panels?
As you said that your HotSpring Vanguard had created a small leak, so you have to start by interfering in one of them and just pull it off gently. You need to remove the old staples, slid the panel under the tub liner and used some real small finish nails instead of the staples.
Once I've pulled out the destroyed foam and rebuilt the frame, what do I use to replace the foam insulation?
You can use spray that can expand foam insulation to fill in around the tubing. But, spray foam doesn’t expand that much, so just make sure that the foam has been just to provide some freezing protection for the tubes.
But remember, that as you said that termites had eaten the frame, so next make sure that you should check out the forum regularly and if you saw any damage immediately call the termite inspection NYC services because termites can rapidly eat out the internal sections of structural timbers mainly the spring wood.
