What kind of filter do you have? sounds like you run the backwash directly to the pool?
It should normally not be a problem because you have a higher pressure going to the pool then to the waste.
The dirt in your pool now should clear up again, use a pool cleaner robot if you got one to speed things up.
and maybe shock chlorine the pool.
If its still cloudy then use some Flocculation
