thoma004
thoma004's Achievements
  1. Hi again all, I have a Hot Springs Hot Spot SX that isn't heating. I'm able to set the target temp and the spa will attempt to run and heat up but after a while I get the following error code while the jets are running - display reads ===== with 'ready' slowly blinking, with filter cycle icon in lower right lit and jet icon in lower left lit. I already replaced the electronic pressure switch thinking this would solve the problem, but it's doing the same thing. Any guidance is much appreciated!
  2. well I replaced the part (and wire) and it is still doing the same thing - any ideas? TIA
  3. Hi all, I have a Hot Springs Hot Spot SX that isn't heating. I'm able to set the target temp and the spa will attempt to run and heat up but after a while I get the following error code while the jets are running - display reads ===== with 'ready' slowly blinking, with filter cycle icon in lower right lit and jet icon in lower left lit. I feel like I may need to replace the electronic pressure switch because it dripped slowly for a couple minutes when I first turned it on. Any guidance is much appreciated!
