fastdriver_0
fastdriver_0's Achievements
  1. Nothers worked until I bridged the flo sensor. After I bridged the sensor and pushed the pump button on the controls I hear a click, the heating element comes on (I feel it getting hot) but no water movement. I checked all the fuses with a Volt meter and they are all good. My pump was taken apart and checked last fall when I had to replace the impeller. It turns freely as I took it out last week to check that. Could it be the transformer on the circuit board?
  2. Hi, I have an older coast spa, pump was just serviced last fall but during the winter the spa stopped working. I narrowed it down to the pressure switch failing, I replaced it but not when I power up the system I hear the heater engage but the pump will not kick in. I hear the relay click when I push the button but nothing from the pump. is there anyway to tell if the temperature sensor is also damaged and not letting the pump kick in? I am not even getting s basic circulation form the pump. thanks
