Outside hot tub was used successfully one night at temperature of 101 F, next morning - tub at 91 F and dropping (20 degrees outside). At the time - the jets work - controller functioned, waterfalls functioning - which is typically tied to need for heat. No heat. I reset by shutting power off to the tub and turning back on. No controller lights at all now - not even watchdog mode ----. I drained the tub due to fear of freezing the water, and installed small space heater within the cabinet - with thermostat. Capacitors do not appear to be bulging or expanded.
How do I test the controller to determine if circuit board or controller is at fault. I have power to the circuit board and on both sides of the fuses. I pulled the fuses and checked for continuity.
Is there a method to identify power / signal from the circuit board to the controller?
Suggestions?
