I picked up a used 2010 Hot Spring Sovereign a couple of months ago, and have noticed a small leak that seems to be getting worse. It's installed on a base of crushed concrete and there is no obvious water pooling up anywhere so I wasn't sure where to start. The water loss is less than 1" per day. The control panel is dry everywhere, and I have removed the light shroud which is also dry. To help with debug, I've been draining it to each jet level and checking if it's still losing water. The water in the main area of the tub has stopped dropping now that it's below the filter compartment vents, but the filter compartment continues to drop. With nothing powered up, the water in the filter compartment is now lower than the main tub. Would this indicate a leak in the standpipes or plumbing below the filters feeding the pumps?
It's mostly above freezing here for a couple of days, so I would really appreciate any advice to get it fixed instead of winterizing :-)
Thanks!
