Hi guys, first post here and I am a bit stumped.
QCA spa I have had since 2004. No issues I could not repair until now.
I drained and refilled the tub to change out the water last weekend (I do this monthly). Everything seemed fine and I went to go in 3-4 days later. Temp was only 91. Heat indicated was on steady, no error codes, jets seemed fine. I figured it may have air locked, but it has never done this before so I burped it at the pump union. Still no rise.
Next step was the filter. I removed it and let it run and the temperature shot right up to 104 in a few hours. Thought I had it so I replaced the filter, which was fairly new and pretty clean. Came back a couple of days later and I am at 97. Temp set for 104. Water temp is accurate at 97.
What could suddenly cause the presence of a filter (new or older) to restrict the heat?
I should also note that I checked all the settings and the circ pump is running 12+ hours per day, not on economy mode, and both speeds on the pumps seem to have normal flow through all jets.
i replaced the heating element 3 years ago, and both pumps are witching 2-4 years old.
Any ideas?
