pappy12
pappy12's Achievements
  1. Looks like this thread is a few years old - But the problem still rages on!! I have a slightly different control panel. I've attached the image here: Note that this control panel is not the original control panel that came with the spa, it's a new board (well I say new, it's about 4 years old). It has been working perfectly up until now. It has two cycles, low speed (filtration / heating), and fast speed. Normal operation is that the low speed comes on and switches off automatically as needed (for example, when the spa needs to heat up or when it's on a filtration cycle) - My filtration cycle is set to F2, but you can set it to F4, F6, F8 and FC from memory. My problem is that the filtration cycle stays on 24/7 - never goes off. When I press the jets button, the fast speed comes on as normal. When I toggle it again, it goes back into filtration cycle again. The spa seems to maintain it's 38 degree setting as normal. It doesn't go hotter or colder - so the heater must be working and switching off/on as when required. The spa does have a proper thermal cover and we live in UK, so the temperature is below that which is required to maintain the spa's without the heater being needed off and on! The filter is pretty new and clean, so I don't think it's that. I don't know how to reset the spa. Although I have tried switching it off at the mains, leaving it for 15 minutes and turning it back on again - no effect. Any idea what might be keeping the filtration system on 24/7 ?
