I've got a Caldera Geneva hot tub that I bought new in the fall of 2012. Aside from replacing the cover this year, I've really not had any major issues with it up until now. Yesterday, I noticed water on the ground around the edge of the spa. I pulled the side panel off to check things out. There was water around the circulation pump. It was leaking out slowly. It appears to be leaking from the large ring that you can tighten with a pair of channel lock pliers. I tightened the ring but it did nothing to stop the leak.
My questions are:
Is there an O ring that I can change within the large ring in the middle that I tried to tighten? If there is an O ring, where can I buy it? If there is no O ring, do I need to replace the whole pump? If I need to replace the whole pump, where is a good place to buy one?
I've attached pictures to show you what I'm dealing with.
