Hello Everyone.
Reaching out here, in the hope of some of your wisdom and help pls.
Guess what i did ? Yup. chlorine capsule escaped to the bottom of the above ground (bestway) pool.
i didn't see it until the following morning. By then, the chlorine had burnt through (dissolved) top layer of the pvc liner. through to the mesh layer. i did panic, but actually it didn't see to be leaking much water since water pressure seemed to seal the other pvc layer, to the floor (ground). the affected area is about the size of my hand.
i tried putting on those pvc repair patches. but they float off within an hour.
water pressure when the pool is full seems to prevent much water leaking. but i really want to patch / cover up the area where the pvc top layer has dissolved. or to buy a large (1 foot square patch) and attach that.
does anyone have any tips or suggestions ?
ideally if i could just get a strong glue / adhesive to cover the abraissed area (when the pool is empty) then maybe ?
i thought of even a strong silicon that you put around the bathrooms seals? but kids jump in the pool and so there feet i would assume would wear away the silicon.
is there like a paint glue i cant jut put over the affected area, to give it a rubber seal ?
(i'm intending on lifting up the pool, and putting another layer of plastic sheeting underneath so that water pressure again forces the pool liner into direct contact with a plastic flooring, prior to the ground.
very much appreciate any thoughts.
(i'm in south italy, and so dint have the abundance of DIY stores i'm sure you luck people have elsewhere)
jez
