I've obtained (free) a 2002 Tiger River Bengal, 115 v Spa. 1st problem is jets only pulse when “Jets” button is pushed. Previous owner thought heater wasn’t working either. The LIM LED (green) is on. Heater has been set down to 80 so it doesn’t come on. When the heat is turned up after ~a minute SPA shuts off. When “Jets” button is pushed LED D18 flashes and the motor tries to get the jets going. You can hear the relays switching. I’ve bled air from lines, can hear motor running, can see shaft turning, can't tell if impeller is turning. The “comfort control system,” smart jet lever is turned to 3 o’clock. Water pulses out of “comfort control system” area. I’ve tried turning lever to other locations, it turns easily, though not sure it is actually moving.
The Spa had been empty and unplugged for a couple years. Pretty sure I’ve got, at least 2 issues to resolve, Jets & heater.
