I will try Ahh-Some purge but it seems like the Spa Purge was working as far as looseining up the biofilm. Let me run this by you. I did 4 rounds of SPA PURGE and dumped 4 different times which means I've dumped 600 gallons of water containing biofilm out. Each time I dumped the hot tub I also took a shop vac and suctioned each jet (all 46 of them) out. I than filled up and did Nitro's decontamination method. I balanced the water, bleached it, opened up all of the jets, ran it for an hour and than dumped it. I completely cleaned the hot tub and cover and filled it back up today. I was preparing to start my chemical cycle(balance and add sodium bromide to start a reserve) when I noticed that when I turned my jets on more biofilm came out filling the tub as if I did NOTHING to it!! My question is if I see the biofilm floating is that still an issue OR am I to the point where my chemical cycle and sanitizer will kill whats left? To be clear since I noticed the biofilm and dumped the hot tub I have not even gotten to a point where Ive been able to fill and sanitize it for use and keep the chemical levels steady because I see biofilm floating every single time I fill it and hit the jets. I'm going nuts!
