I have the same problem with my Jandy aquapure 700. I believe the problem to be the sensor, I have even tried to remove the daughter board but then received the appropriate error codes indicating sensor problems, so I went back to the same configuration with same results daughter board flow light blinking and no flow indication on Jandy controller. Temperature and chorine reading are correct.
Does anybody know the pin out on the flow sensor cable, since all other readings are correct I would like to bypass the flow sensor.
