jmoffett
  • Content Count
    2
About jmoffett
  1. I removed the fuses and checked them for continuity with a multi-meter. I also checked the pump voltage at the connector on the board...zero with the switch on or off...while the same method for pump 1 showed the correct voltage with the switch on. I'm at work and don't have a picture of the board at the moment, but nothing looks burned or damaged. I removed the pump 2 connector from the board to look at it. Nothing looked out of the ordinary and it separated and snapped back on easily. The spa is a 2012 model that I bought in 2015 and I replaced the circuit board a couple years ago. I have th
  2. I have a Catalina Spas swim spa with a Balboa EL Series/CAT2000 controls and Pump 2 will not turn on. The light on the topside controller comes on and I can hear the relay on the circuit board clicking, but the circuit board is not supplying power to the pump cord. There are two 30a fuses and one 20a fuse on the board and they are all three good. Any ideas?
