Hi,
Does anyone know the start up procedure for a Northwinds spa? A friend of mine suggested that it might be priming and just leave it for ten minutes.
When I power it up both pump lights on the control panel come on by themselves and they CAN'T be turned off. If you try to turn pump 1 off with two
button presses it will go off for a few seconds and then the light comes back on. Button two does the same thing but it only takes one press to turn it off.
It's also displaying the word ICE but the temps have been well above freezing and the side access panel was open to a 20 deg sun for 2 days.
The manual is crap as usual because it was written for a generic tub model so its useless ..... it says: " Your spa will enter Priming Mode (Pr) when it is energized.
During Priming Mode, press Jets button repeatedly and be sure the pump is free of air. Priming Mode lasts less than 5 minutes. Press Temp to exit. After
Priming Mode, the spa will run in Standard Mode (see Mode section). Some panels may not have a Temp button. On these panels the Set, Warm, or Cool
buttons are used. "
With my tub with energized both lights come on by themselves and just sit there and the tub makes no noise at all.
Cheers'
Dave
