firehots
firehots's Achievements
  1. I was wandering if anyone owned one of these spas. I just got one given to me. There are several lines that are disconnected inside the compartment. I can not find any good images of inside, or any plumbing diagrams. there is one line coming from the top left under top that has a broke off plastic barbed end on it. there is two lines coming from upper left. One has a check valve with a 3/4 threaded end on it and the other is longer and also has a broken clear plastic nipple in it. There is also a small line coming from the bottom center that has a clamp on it with no fittings attached. When tub is full of water that small line flows water out. The only thing I can figure is that all the lines had check valves on them.. Any info or pictures would be of great help. I blew air through all the lines and they each go to a different set of jets.....
