Hi guys, I was hoping to find some help here if possible.
I recently acquired a hot tub with a house. I got some advice from a friend who is a spa dealer, I cleaned the tub, changed the water, superchlorinated and all was good.
I had a hot tub party (7 bathers, a few hours) a few days ago and afterwards, due to some water loss, I topped up and tested levels only to find, to my surprise, that there was 0 chlorine. I usually have 2x chlorine tablets in a floating dispenser and this keeps FC and TC around 5ppm usually, sometimes slightly higher than I'd like. I added a few more chlorine tablets, with no apparent effect and then an extra one, and only now the FC has just started to register at nearly 0.5ppm.
I'm worried about low chlorine levels and bug growth, so I'm about to pile in a load of extra tablets. After reading some posts regarding Chlorine Demand, noting "100% CD is Bad. This could mean you just had a Hot Tub Party...", is this chlorine behaviour normal after heavy use, and will extreme superchlorination help get things back to normal, or do you think there could be underlying issues?
Bear in mind the tub was cleaned and refilled (twice) only a month ago, levels have been rock solid (usually too much chlorine) and it has only been used heavily this one recent time. Thanks!
