Amik
  • Gender
  • Location
    Montreal, Qc
  • Gender
Amik's Achievements
  1. Is it normal that my pH is always rising fast and difficult to keep to 7.5 ???
  2. Hi Giahosa, First thing : Smoke from a breaker is NOT good. The lug on your breaker for the red lead seems all burnt. Close your breaker in your main panel and replace your GFI breaker. Assure that your red, white and black lead are correctly torqued in the breaker, a loose connection can lead to a fire. Check also the connection in your spa to assure that everything is tight. If the breaker trips again after replacing the gfci, you'll need to check the amperage of the spa and use a megger to check if the heater is "leaking to ground". Hope this helps
  3. Hi to all, I'm a new owner of a spa ( 3 days of use ). I am using Brome as sanitizer and using Waterbear Brome for Beginner !! A little bit hard to adjust everything but getting the feel for it. What's the waiting time between 2 chemicals or before entering the spa. BTW the forum is great and does help a lot to have a great spa experience. Thanks for your help
  4. Hi to all, The forum is awesome !!! I was shopping for a Taylor test kit from canada and found the chlorine and bromine kit in sale !!! Not the same price as US but a good price. http://piscines-apollo.com/cubecart/
