5koliny
15 -
2,700 profile views
5koliny's Achievements
Hey guys, I went out to check the Hottub and the circ pump looked like it was barely pumping anything into the water. The screen (display controller thingy) had nothing on it, and would not respond when a button was pushed. There is nothing on the screen. The hottub is setup to heat up to 104˚F constantly. The water must have been in the 60s, which means its not heating. Also, in some parts of Texas right now its 28˚F outside. Last week it was in the 70s. Could the weather have an effect on the hottub's behavior? And if anyone has heard of anything like this, whats your diagnostic? Thanks everyone, -5k
I should assume that the fake CAPTCHA is not harmful in any way, right?
Pump Is Doing Some Weird, Weird Things.
5koliny replied to 5koliny's topic in Portable Hot Tubs & Spas
Nobody? -
Hello, My Master Spa LS700 is having a pump problem. When the pump is plugged in, and the circuit breaker is activated, it will trip. But occasionally, it won't. When it does not trip with the pump plugged in the pump makes a HUMMMMMMM without even being activated. When I activate it through the topside panel, it turns on, pumps water and then HUMMMM (when HUMMING it won't pump water). This happens every 4 seconds. Some people say its the capacitor, but if thats the problem wouldn't it not even pump water in the first place? Thanks! -5koliny
Thanks!
Hello, I have an older MAS560 circuit board with M7 heater technology. It always says that the flow is low, but the circ pump that pushes water through the heater is running, and water is coming out of the outlet in the tub. The filters are brand new (3 days old). What could be the problem?
Does the big jet have 15 or so nozzles? If so, thats the master blaster. On my Legend Series 2003, the master blaster is on its own pump. I just recently got the pump working that is only for the master blasters, and for a while, wondered what the extra air valve went to.
Down East By Master Spa Jet Configuration
5koliny replied to agombash's topic in Portable Hot Tubs & Spas
Thats correct, thats how they should work. But just to be safe, make sure all of the jets are open by turning them when the pumps are on. -
OK, I think I found my problem. Therapy 1 and Therapy 3 are not getting enough power and when they don't get enough power, the circ pump runs. I think thats F***ing with it.
- 6 replies
- circulation pump
- Master spa
You said you don't notice anymore power with a 2hp or a 3hp pump. Down East spas always have a diverter. Maybe you need to direct the flow of the diverter valve to one set of jets only, and test the pumps yourself. Now with the tub having a 2 speed motor but using 1 speed (high most likely), You need to make sure the power is off, remove the skirting that is in front of the topside panel, check the circuit board to make sure that where the pump is plugged into that it has 4 wires (On both the circuit board and pump side). If it does, then check the dip switch settings on the side of your circuit board. Make sure Pump 1 is set to 2 speed mode, not 1 speed. If you only have 3 wires and not 4, then there is your problem.
OK, I just set the exterior dip switches correctly. Pump 3 will activate (after 7 years)! But heres the weird thing. Pump 3 seems to be connected to the circulation pump. When Pump 3 is on (no matter what pump slot it is connected to on the mono) the circ pump comes on. I saw another set of dip switches on the inside of the panel, could these be causing something? EDIT- I realized I said "mono". I meant Mobo.
- 6 replies
- circulation pump
- Master spa
Thank you for your response. Im going to go check and look at that right now. Thanks!
- 6 replies
- circulation pump
- Master spa
Well this might not be a smart idea, open the panel on your hot tub (Make sure power is off), then open up the circuit board. There should be a little plug that the main spa light is plugged into, just unplug it. If that does not work, Just take out the lightbulb for the time being until you get a permanent fix.
Hello! I own a 2003 Master Spas Legend Series with 4 pumps (1 circ, 3 jet). Pump 3 (Therapy 3) will not run. I have done some troubleshooting and I have determined it is not the topside control (when it is on standby mode and I push therapy 3, it wakes the spa up but won't turn on the pump) and I know the pump works FOR SURE. Now for the circ pump- It won't run when Therapy 1 is on, but when its off, it works fine. I have no idea what is going on. Thank you! -5k
- 6 replies
- circulation pump
- Master spa
