If the heat light is not on, adjust the pressure switch PSI, and if it the light does not come on when pump is on low speed with any PSI then the pressure switch is no good.
If the heat light is on, the tub is still not heating and you're only getting 120V to the heater, the heater relay on the board is no good meaning you need a new circuit board.
hope that helps
