i have a 2006 Tiger River spa and i have had a blinking light problem for years...once or twice a year i would go out to the spa and find the light blinking. i would reset the breaker and not have a problem for 6 months. occasionally i blamed it on the filter...so i would replace the filter and it appeared to fix it....but it would always happen again.
tonight i went to check on the spa as nobody has been in it for several months...and everything looked fine. So i cleaned the filter w/ the hose, knocked the silver ion a bit (there was some white crud on it) and tossed in some chlorine. i turned on the cleaning cycle and it ran for 30 seconds and tripped off...it hadnt tripped off in almost a year, but we hadnt used the spa more that a handful of times....fyi, we always keep the spa set for 100 deg.
i thought it might have been the filter...so i removed the filter and reset the breaker...same thing, it trips out in 10 seconds. i reset it like 5 times...you turn on the jets and it'll trip off in seconds.
does anyone have any suggestions? the recirc pump appears to be fine, i still get bubbles from the heater outlet like normal...you turn on the jets and everything seems normal there too....until it trips off.
anyone have any insight?
