New guy here. I've be reading the forums feverishly for a few weeks now.
I just got my new Taylor K-2106 Water Testing kit! I was so anxious to try it. I filled a water bottle with my Spa Water and began my testing.
Here's what I found:
pH = 7.2
TA = 50 ppm
Bromine = 37.5 (what?!)
I did the test both ways. First the 25ml sample. Never turned clear. Then I washed the vials and tried again. Water turned pink and I began my drop and swirl. Drop, swirl, drop swirl. 35 drops later I bailed out. Tried the 10ml test. Drop, swirl, drop, swirl. 30 drops later it finally turned clear! 30 x 1.25 = 37.50.
I immediately went to my 4 month old spa and pulled the bromine frog cartridge. Terrified I had set it wrong. I set the cartridge to the side and turned on the jets to get this (seemingly) high level of Bromine out.
Then I got to thinking. Isn't that a bit off the charts? I went back to my cheapo, store bought drop tester. The Bromine vial showed almost no Bromine (looked like less than 1ppm). So I added some clorox bleach (4 oz). And the cheapo test perked right up to a bright yellow (probably 8ppm).
Then I thought, perhaps when you have a low amount of Bromine in the Spa, the Taylor test is inaccurate. So I did both tests on the Taylor again. This time I could not get it to turn clear EVER. So I went and pulled out my test strips to see what they would say. They said about 6ppm.
Now I am more than half depleted of the R-0872 titrating reagent. Can someone tell me what I am doing wrong? I followed the instructions TO THE T! Re-read and tried again. Researched and tried again. Always the same bad results.
I either have a super brominated tub or things are really ok. Not getting in until I get this thing solved.
Any help is MUCH appreciated!
Data:
Marquis Epic Spa, 450 Gallons, Bromine always, Mineral cartridge installed, water changed 1 month ago. Borate at 40ppm.
