Content Count
71 -
0 NeutralAbout Jason B
Rank
Spa Savant
5,991 profile views
Jason B started following Advice On Clearwater Spas, Overdose of citric acid, Balboa spa circulation pump shuts down and 2 others
citric acid Overdose of citric acid
Jason B replied to Nanskier's topic in Swimming Pool Water Chemistry
Great site!!! I’ve posted it on some pool forums I’m on. https://www.medallionenergy.com/blog/pool-stain-removal-guide/ Question, in the past I’ve gotten vitamin C/abscobic acid and it removes metal stands for my steps and parts of the liner. It works great, now that vitamin C powder has tripled in price and I see citric acid powder for super low prices. Will this do the exact same thing? And does it work as good as the vitamin C? -
Anyone else try the Vitamin C trick? I'm about to order more!!!
Outdoor Hot Tub Base Of Gravel And Wood?
Jason B replied to yesterdayze's topic in Portable Hot Tubs & Spas
The tub I'm looking at made by clearwater that is 74x74 it's a- 4-5 person tub. Clearwater spas has many models that are 74x4, but your smallest pad is 96x96, and that won't work for me. I -
Ah, yea, that looks exactly like my pool solar cover! Ha, probably same material. THe only real way to test it one month with it off, and one month with it on I may add a meter when my tub is hooked up so I can know the exact amount it's drawing for fun. Meter is cheap I hear.
Cool. link to it? I'd think it could only help.... How much do you think your electric bill is addtional per month? And what KW rate are you at?
Jason B replied to kheisler's topic in Portable Hot Tubs & Spas
So, you fix it? And what model Clearwater? -
I think I read this really helps??? Am I right?
Clear water XS 5 person spa, used, thoughts?
Jason B replied to Jason B's topic in Portable Hot Tubs & Spas
As I was doing more thinking, I think it's better than the marquis for my application because it's going to be fully recessed into screened in porch deck, which is 35" off the ground, which I think will work out better if and when there is a leak (porch it's surrounded by removable lattice wood so you can get inside access). If I went with a full foam tub and it leaked, there isn't going to be an easy way to find a leak in a full foam tub (i've seen videos when a full foam tub leaks they had remove the tub sometimes to find the source of where the leak is at) which won't be something I can do -
This seems to be what you want as that other product you used didn't do the job... The stuff you want is: AHH-SOME. Read this! http://boisediesel.com/blog/2016/7/spa-purge
Let's Hear From People With Fully Recessed Spas
Jason B replied to Lips Malloy's topic in Portable Hot Tubs & Spas
Can you add the pics again? FOr some reason can't see them. This sounds very nice. -
I never ending up doing this project but think I'm going to now. Anymore installed pics by people recessing into their deck? And when you say patio stones instead of concrete, what do you mean? Or XPS insulation (10 cm thick) , never thought od that. How's it holding up?
wow, very detailed write-up. So if I'm buying a used spa, I'd want to do this first with the ahhsome?
Jason B started following Energy consumption
I'd like to k now aprox for all your guys how much your electric bill went up after adding the spa aprox? ALSO, why doesn't anyone heat their spa with propane? If you have a pool heater most use propane to heat their pool. Why doesn't anyone do that with these type of tubs? They'd heat up to any temp super fast.
Yea, photobucket is crazt if you ask me. Would be cool to see pics. You can use another free site also called http://imagetwist.com/
