Hi, I'm new to the forum - nice to meet you guys. I've recently purchased a home (in November) and I've been slowly getting the pool into order. When i moved in it was a swamp - i've since gotten it pretty much pristine. The previous owners had the bottom of the pool repainted at one point and it really looks great when it's in top shape. That said, right now the skimmer line is clogged (tons of trees, so i'm assuming it's leaves) and I'm likely going to need someone with a co2 gun come out and clear it - so it's a bit murky right now. But that's not why I'm here. I'm here to show you guys some of the plumbing and ask some questions about it, so here we go!
First, here's a picture of when it's look good:
Ok, so here's my skimmer:
and here's some weird hole, water doesn't come out of it - it might be threaded, i was told it might be for a vaccum which would be great because im tired of running the kreepy krauly and manual vaccum from the skimmer:
here's the plumbing:
Some of the equipment:
New wisperflow pump for the pool and spa circulation Old (i forget the brand name) black spa jet pump (under the bubbler) Two Chardonnay valves A very old filter An equally old heater A bubbler Some X10 stuff (X10 sucks) not shown
Close of of the plumbing:
From left to right:
from the spa to the pump from the skimmer to the pool from the heater to the spa from the bubbler
Here's from another angle, AND some weird capped off pipes (could this be for that vaccum hole?):
So here are my questions:
How might i go about determining what those capped off things are in the last picture. How might i determine what the mysterious hole is How can i tell if the bubbler is working - i guess i do so air in the spa, but the water\air only comes out about a foot, it's not very strong - do i need a better pump for that perhaps? How do you service a bubbler? What can you guys recomend in lieu of X10, preferably something that doesnt' require me to go over to the equipment and manually change valves. Should i bother re-doing all of the PVC here - it looks terrible and it's obvious that a lot of changes have been made over the years. I'd like to add the 'screw on' (for lack of a better word) connectors at various places to keep things nice when changing out components.
Thanks!
