One year old inground... everything is Hayward except Pentair Intelliflo VS. Happy so far but just started having issues with pump. Believe it to be electrical and waiting for qualified electrician. Pentair overnighted a new driver (electronics for controlling motor speeds, etc) so happy with company's response. Plus without additional components I can't connect my pump to my Hayward automation system which you may find if you go with a non-Pentair pump. Good luck.
If you have a 3-way valve I recently had an issue with mine. There is a gasket recessed into the face of the valve plug and it was torn which led to water loss at deck jets, pressure fluctuations, air, etc.
My 1-year old Pentair Intelliflo pump was running erratically for a few days then lost power. I installed a new Driver but that didn't work. It has its own 220 circuit breaker which is installed in a Hayward Aqua Plus and the breaker is showing correct amps on the ammeter. Any ideas about what to check in the panel? There are 4 other breakers in the Aqua Plus and they are all working.
