Hot Springs Sovereign; I think we got it around 2000. S/N is IQ2A2015; it has the IQ2000 controls, and is wired for 220. Two GFCI breakers- a 20A that runs the controls and circulation pump, and a 50A for the heaters and main pump. After a brief power outage two days ago, every time I reset the smaller, 20A breaker, it instantly trips. I replaced the breaker but problem continues. After the power outage, water backed up into the Ozone unit. I've disconnected the Ozone electrically but no change in behavior. I removed the metal bracket that obstructs the main board, didn't see any obvious burn spots or other indications. While the bracket was off, I tried applying power and got a steady red light. I powered off to avoid the shocking hazard while replacing the bracket, and now it instantly trips the breaker again.
I've also tried powering up without the thermistors attached, but no change. They measure 11.61 and 12.64; water may still be slightly warm.
Any clues? At first it was just the red blinking light syndrome; now it won't come on at all, and instantly trips the 20A breaker (the control panel light flashes briefly until the breaker trips.)
Thanks-
Paul
